04-09-2011 02:15 AM
Dear all,
04-11-2011 03:07 AM
Hello Ustcmiaor,
My experience is that CPU performance does not say it all.
If you have a i7 CPU then see forum post:
The "Resend packets received" should be there. I can only guess why it is not there.
- The camera will not send them , due to settings or due to hardware problem.
- Maybe your resend time out is to long. I do not know what values should be for a line scan camera. I have value of 5msec.
- You should try pro1000 card. But in my opinion "Resend packets received" should also be there without pro 1000 also.
Please check your driver because the pro1000 card should use the right driver
For further details see basler:
http://www.baslerweb.com/beitraege/faq_en_73858.html
http://www.baslerweb.com/downloads/21258/Interface_NI_Acq_SW.pdf
Kind regards,
Toine
04-11-2011 10:30 PM
Hi, toineroetman,
Thank you so much for your help.
The default resent time out is 2 ms for my camera in MAX, and use this setting, I got no resent packets.
After increased it to 100 ms, I can get 80% of the resent packets in a relatively low frame rate. However at high frame rate, still no resent packets received.
I ordered an intel pro network card online, I will try it after I got it. Hope it can solve my problem.
Miao
