Machine Vision
acquistion timeout problem when working pcie1433 and Baumer SXC10.
Dear all, I'm working with a vision system.the camera is Baumer SXC10, framegrabber using NI PCIe1433.
cause there is no camera file for the camera, so I have to use camera file generate tool to cread it. but saddly the file doesn't working.
IMAQ using Image Aquisition August 2010.(version:4.7).I can use seriel port to communicate with camera, the tool is
Baumer CL configtool. did this prove that the cameralink port is working.
I only wish to grab image, so I think there is no necessary to add camera control(in camera file tool). So did I must add it to my camera file?  Baumer announces SXC10 working properly wish Pcie1429,So I think 1433 can working!
is there some way to find the reason?
waiting for your answers,thank all of you very much!
(3,128 Views)
I think the camera should work with this grabber, since the serial port can communicate with camera,  maybe it is a cable problem, please try another cable and make sure that the camera and the grabber is well connected!
(3,043 Views)
