 Hatef.fouladi
			Hatef.fouladi
			10-28-2017 12:33 AM
10-28-2017 03:16 AM
Hello Hatef,
Linescan camera and LED line illumination are in a cabin. A small finds you an attachment. Marble slabs are not small (largest 1.8m x 3m)
10-28-2017 03:40 AM
Hello Hatef,
Images of conveyor without slabs finds you as attachments. It's a rolling/running conveyor belt. As you can see conveyor surface is never same. Sometimes slabs are wet, the conveyor surface become wet too.
10-28-2017 03:45 AM
Hello Hatef,
Images of conveyor with slabs finds you as attachments.
 Hatef.fouladi
			Hatef.fouladi
			10-28-2017 04:43 AM
I check you image and video
if you have restriction to change your camera or other device, at least change your light wavelength
green light is not suit for this project I find the light with wavelength that have more absorption in your marble
it will be make your marble more darker and easy to find edge I think  IR light may be work (use spectroscopy to find   best light )
anyway also I test some edge detection algorithm it seem rake could work just need to select active correct ROI
and search for edge with rake algorithm in 4 direction but with appropriate ROI
see bellow result
at the end still I strongly believe that you have to have change in your vision device to get best answer
10-28-2017 05:35 AM
Hello Hatef,
We use not green light. we use white light (6500K). What you see is natural colors. Conveyor sides are green paint, conveyor surface was darkgreen with blue tones (but now not homogenaus because of marble dust and wet areas) and marble slaps are blackish (with white areas)
We can't chance our vision device (IDS uEye Linescanner camera)
Also marble slabs are not always rectangular.
 BruceAmmons
			BruceAmmons
			10-28-2017 11:51 PM
The problem is that the images you have shown us are almost impossible to separate the marble slab from the background. With both the background and the marble slab being multicolored and textured, the standard tools just won't work very well. The only way we see to solve your problem is to revisit the acquisition method. It may be an option that costs more than you want, but it would solve your problem.
I do remember that the Sick camera had the ability to function as both a line camera to take a normal image, and height measurement camera. This would provide you with both images you need, and you would be able to find the outline of your marble slab and analyze it very easily.
Bruce
 Hatef.fouladi
			Hatef.fouladi
			10-29-2017 02:30 AM
10-29-2017 02:34 AM
Hello Bruce,
you're sure right. I'm aware of problem that both the background and the marble slab being multicolored and textured.
Although grayscale imageis not multicolored:
But I think/thought there may be some methods or mixture of methods (gray morphology, segmentation, background subtraction, etc.)
that helps me to solve my problem. I reach some results with my own work but these are not a general solution until now.
There is (in my opinion) some more difficult applications. For example:
"A machine vision-based approach to measuring the size distribution of rockson a conveyor belt"
https://www.dip.ee.uct.ac.za/publications/theses/MScSimphiwe.pdf
Some images from this paper:
10-29-2017 02:38 AM
Hello Hatef,
I work with monochrome image, not with color image. Color image is for the costomer.
