Machine Vision
MAX 4.2 problems with identifing CVS
I have another problem that came with installing VBAI 3.0.1. It also updates the MAX to version 4.2. I cannot locate the CVS using the Create New... for Remote devices. When I enter the IP address, it says that the device on that IP is not supported.
Any ideas?
Martin
(3,466 Views)
And there is a second problem with MAX 4.2. When I close the application an error dialog box appears with some Pure virtual function call. I attach the screenshot.
Martin
(3,462 Views)
Martin
In order to successfully detect the CVS through MAX and VBAI, you need to install the CVS support. The CVS support is installed with NI-IMAQ I/O which ships as part of Vision Acquisition Software.
Hope this helps,
JohannS
(3,418 Views)
