Mark,
On the second laptop, the one running Win 2000, I uninstalled all Vision, IMAQ and IMAQdx software then installed NI Vision Acquisition version 8.2.1. The NI license manager still shows two unlicensed components, the Professional Development System with Mathscript under LabView 8.2 Development System and the Remote Panels under LabView 8.2 Toolkits I mentioned earlier. I'm not sure how to remove these two components in the National Instruments Software menu under Add/Remove Software.
You mentioned I should install only the IMAQ for 1394 driver. Is there a way to install a standalone driver instead of the full NI Vision Acquisition version 8.2.1?
The first laptop that does work with the camera only works at 30 fps or less which is OK with me. But 60 fps would be nice.
I was using the PCMCIA to PCI adapter because the only interface I have to my PXI-1042 is the 8310. If the 8310 is causing the problem I'd be happy to exchange it for a direct PCI interface.
You mentioned that the 8310 has a max throughput of 50MB/s. In MAX when I am setting up the camera it only gives the option of using 100, 200 or 400 MB/s for the camera speed. Could this be the source of the problem? If that is the case I don't know why it worked on the first, and much older, laptop.
Your idea about the PCMCIA converter causing problems does not explain why the same system freeze happens under the same circumstances on the second laptop with a direct PCMCIA connection.
I am currently installing the Vision 8.2 Development Module on the first laptop. I will post again after I've tried it out with the camera.
Mark
