03-02-2007 08:44 AM
03-05-2007
05:51 PM
- last edited on
04-22-2026
10:39 AM
by
Content Cleaner
Hello Johnny,
Thank you for using National Instruments Discussion Forums. There is actually a really good tutorial and example utility that allows you to configure VBAI Inspections for use in Test Stand. I believe in the utility you have the ability to keep the Active X reference open throughout the steps so it might improve your processing time when switching between inspections. I hope this helps. Thanks and have a great day.
Running a Vision Builder AI Inspection from TestStand
Mark T
