12-25-2009
06:00 AM
- last edited on
04-19-2026
12:55 PM
by
Content Cleaner
From my university I got a license for Labview 2009 + Vision 8.6 Module... Now I installed Labview first of course. And when I was finished I installed the vision module. Both installations went very smooth. Now when I start labview I don't have acces to the any labview vision vi's that should be provided...
As what I read here http://www.ni.com/support/labview/lvtool.htm#vision_development the module should be compatible with labview 2009... So anyone can explain me why it isn't showing up in labview 2009?
12-28-2009
04:30 AM
- last edited on
04-19-2026
12:55 PM
by
Content Cleaner
Hello Wouter,
Please see the following link: https://www.ni.com/en/support/documentation/compatibility/17/labview--labwindows-cvi-and-vision-deve...
The NI-Vision Development Module isn't compatible with LV 2009.
With kind regards,
Casper
12-28-2009
04:41 AM
- last edited on
04-19-2026
12:56 PM
by
Content Cleaner
CasperK wrote:
Hello Wouter,
With kind regards,
Casper
But this is misleading
| Module | Platform | Version | Required LabVIEW Version |
Minimum LabVIEW System |
| LabVIEW Vision Development Module | Windows | 2009 | 8.2 (or higher) | Base |
| 8.6 | 7.1 (or higher) | Base | ||
| 8.5 | 7.1 (or higher) | Base | ||
| 8.2 | 7.1 (or higher) | Base | ||
| 8.0 | 7.0 (or higher) | Base | ||
| 7.1.1 | 6.1 (or higher) | Base |
Definetly needs some changing
12-28-2009 06:22 AM
@CasperK yes I see now but I came on the website (by google) with the piece of text that Musk provides and there it seems that the labview vision module was compatible and I agree with him that, that page must be changed.
Anyway thanks for your help. Now is everything 100% clear to me.
12-28-2009 06:35 AM
Hello Wouter/Musk,
I can see what you both mean, I will address this to the right person(s) to see what can be done.
Thank you for the feedback.
Casper
12-28-2009 06:38 AM
