Machine Vision
Labview 2009 + Labview Vision 8.6 = Not working...
From my university I got a license for Labview 2009 + Vision 8.6 Module... Now I installed Labview first of course. And when I was finished I installed the vision module. Both installations went very smooth. Now when I start labview I don't have acces to the any labview vision vi's that should be provided...
As what I read here http://www.ni.com/support/labview/lvtool.htm#vision_development  the module should be compatible with labview 2009... So anyone can explain me why it isn't showing up in labview 2009?
(4,605 Views)
Accepted by WG-
Hello Wouter,
Please see the following link: https://www.ni.com/en/support/documentation/compatibility/17/labview--labwindows-cvi-and-vision-deve...
The NI-Vision Development Module isn't compatible with LV 2009.
With kind regards,
Casper
(4,566 Views)
CasperK wrote:
Hello Wouter,
With kind regards,
Casper
But this is misleading
Module Platform Version Required
Version
Minimum LabVIEW
System
LabVIEW Vision Development Module Windows 2009 8.2 (or higher) Base
    8.6 7.1 (or higher) Base
    8.5 7.1 (or higher) Base
    8.2 7.1 (or higher) Base
    8.0 7.0 (or higher) Base
    7.1.1 6.1 (or higher) Base
Definetly needs some changing
(4,563 Views)
@CasperK yes I see  now but I came on the website (by google) with the piece of text that Musk provides and there it seems that the labview vision module was compatible and I agree with him that, that page must be changed.
Anyway thanks for your help. Now is everything 100% clear to me.
(4,554 Views)
Hello Wouter/Musk,
I can see what you both mean, I will address this to the right person(s) to see what can be done.
Thank you for the feedback.
Casper
(4,550 Views)
Thanks for the confirmation and i am muks and not...
(4,547 Views)
