03-15-2010 06:33 AM
Solved! Go to Solution.
03-15-2010 06:36 AM
03-15-2010 06:43 AM
03-15-2010 06:44 AM
What is the camera that you are using. Can you play with the settingsso that you capture a lesser resolution picture? Can you mask of certain region if you are sure you are not going to get useful info from that region. And as i suggested above you can also try the downsampling from vision assistant like this
