Machine Vision
IMAQ dx Error -1074360282 occurred at IMAQdx Open Camera.vi
I have the exact same problem. Probably got into this after some update, not sure.
Does any one have solution? I tried deactivating and activating the VAS and DVM. No luck.
Thank a lot!
Hi I have Labview 2013, and am Running VDM and VAS installed and activated.
However, when I try to run a VAS example such as Low-Level Grab, I get this error, Error -1074360282 occurred at IMAQdx Open Camera.vi
"Possible reason(s):NI-IMAQdx: (Hex 0xBFF69026) License not activated"
Even though I know that VAS is activated, additionally the cammera works fine in MAX and all the VDM examples seem to work.
Any help would be great.
Steve
Message 11 of 14
(3,384 Views)
Hi J_Snow, what versions of VDM and VAS do you have installed? Can you show a screenshot of them in NI License Manager or MAX?
Message 12 of 14
(3,378 Views)
Thanks for replying quickly!
All 2013 versions
In "Ubinstall programs" from windows I found that I have an "NI Labview Run-Time Engine 6.0.2" installed next to the National Instruments Software. Could this cause the problem?
Thanks!
Message 13 of 14
(3,376 Views)
here the screenshot of the NI license Manager
Message 14 of 14
(3,375 Views)
