Hi!
I have Jai CV-A50 camera and PCI-1409 grabber. I need the shutter time from 0.1 to 2.0 sec long. Corresponding to the documentation of camera, I have to establish TR=4 trigger mode, drive trigger line with HSYNC to the camera's HSYNC input and create pulse generation with pulse width about 7.5H and pulse delay =shutter time to the camera's VSYNC input.
Here is a code in LabWindowsCVI, that is implemented to start image acquisition. But I don't get a picture.
What may be a reason?
int CVICALLBACK Start (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
int iErr = 0;
unsigned long delay, width;
unsigned long timebase;
switch (event)
case EVENT_COMMIT:
GetCtrlVal( panelHandle, MAIN_START, &IsGrabStarted );
if( IsGrabStarted )
// create ring
CreateRing();
// conf trigger SHUTTER_TIME_NUMERIC
iErr = GetCtrlVal( panelHandle, MAIN_WIDTH_TIME_NUMERIC, &dblWidth );
iErr = GetCtrlVal( panelHandle, SHUTTER_TIME_NUMERIC, &dblShutter );
iErr = imgPulseRate (dblShutter, dblWidth, &delay, &width, &timebase);
iErr = imgPulseCreate2 (timebase, delay, width, IMG_SIGNAL_STATUS, IMG_IMMEDIATE, IMG_TRIG_POLAR_ACTIVEH, IMG_SIGNAL_EXTERNAL, 0, IMG_PULSE_POLAR_ACTIVEL,
PULSE_MODE_TRAIN, &pulseId);
iErr = imgPulseStart (pulseId, sessionId);
iErr = imgSessionTriggerDrive2( sessionId, IMG_SIGNAL_EXTERNAL, 2, IMG_TRIG_POLAR_ACTIVEL, IMG_TRIG_DRIVE_HSYNC );
iErr = CmtScheduleThreadPoolFunction( DEFAULT_THREAD_POOL_HANDLE,
GrabAndProcess,
NULL,
&threadId );
else
StopGrabThread();
break;
return 0;
GrabAndProcess function is OK, if I send TR=0 to the camera, it works normally, but shutter time is not that I need.
Thanks.
