Machine Vision
How to build an application in LabVIEW 10 including FLIR Thermovision Toolkit 3.3
I don't think the tcp/ip protocol from Flir is open.
Message 31 of 86
(4,990 Views)
If you cannot communicate on low-level TCP/IP with this camera, you might want to ask them if there's any interface that can be used. Ask them about Ethernet, USB, FireWire, Serial, anything. Once you find that out, then you can ask whether that same interface will work with LabVIEW (most of the time the answer is yes, it's just a hard task to do a lot of the low-level organization of data into image data).
Ravi A.
National Instruments | Applications Engineer
Message 32 of 86
(4,982 Views)
Hi ulfn ,
              If i buy the Flir toolkit what are features they  provide .Do they give and special vi consisting of algorithm for image processing or its just going to grab the image and displaying .
Message 33 of 86
(4,964 Views)
Hi ulfn
Thanks . so ill get an GIGE camera in which i can do these thing using the IMAQ dx .
Message 35 of 86
(4,958 Views)
Hey everybody,
I was finding solution for my problem, and looked your discussion, seems like you ppl could solve my problem. I am workng with FLIR A40 cam with labview. I was tring to read the temp image in the labview by the examples given in the labview toolkit. But I am getting an error as "Error -1 occured at Thermovision open.vi Failed to connect camera. Error code#1,Device not present", But i can identify the cam in MAX and view the video in it, but while running the labview coding, its giving me the error. Do anybody know the solution. Pls let me know ASAP as I my project deadline is near.
Message 36 of 86
(4,917 Views)
Nichoo, how is the camera connected to the pc? Ethernet? The toolkit is based on active x and it can be tested manually from labview with one of examples under labview\exemples\thermoviosion\. You have to select correct camera, ip-address and interface. Try to connect to the camera from the active x control by pressing connect button.
Message 37 of 86
(4,912 Views)
Hi Ulfn,
Thanks for replying me. The cam is connected to the PC through firewire1395. I have entered all the cam name, connection port and the serial number of the cam shown in MAX correctly, but still I get the error. What is the active x mean? the cam shows up under Imaqdq in MAX devices and interface, but in the labview examples, eventhough if i enter al the parameters, its showing error. And where should I click connect in active x?
Message 38 of 86
(4,907 Views)
Labview communicates with the camera with help of an active x component. The active x component is installed and registred together with the thermoviosion toolkit. Normally this component is encapsulated in the toolkit, so you can't see it. By open one of the installed examples you will see the actual active x control and use it "outside" the toolkit. The purpose of this test is to see if there is anything wrong with the active x component.
Message 39 of 86
(4,905 Views)
sorry, I could not get you clearly. I opened the thermovision examples installed in the labview folder and I could not find the active x control. If i open anyone example it opens the front panel of it.
Message 40 of 86
(4,900 Views)
