Hello I have a question to the camera setting in MAX. In the register "Acquisition Attributes" can I set the isochronous packet size. This is understandable to me
But in the register "Camera Attributes", I attribute the possibility of a frame rate to (see picture).
What camera are you using? It would be
helpful to find documentation on that camera's attributes to make sure,
but here's what I can gather without knowing the model.
When
in most modes other than Format 7, "the packet size, framerate, and
Region of Interest are fixed depending on the mode that you use within
that format". My guess is for these modes, the FrameRate attribute is
intended to let you limit the acquisition rate of the camera in order
to have some measure of control over bandwidth use - so by setting the
framerate attribute low, you reduce the amount of data transferred for
a given resolution and the packet size would be fixed (overall, fewer
packets would be transferred).
In Format 7, though, "you can
modify either the packet size or the Region of Interest to
control the amount of bandwidth that will be reserved by the camera and
thus controlling the maximum framerate." My impression with this mode
is that your camera will generally ignore the FrameRate attribute when
in Format 7 and will take the desired packet size and resolution and
then automatically allocate a certain amount of bandwidth for
acquisitions (which means max framerate is adjusted accordingly)
To
summarize, my impression is that formats other than Format 7, it sounds
like this particular camera gives you some control over the free-run
(non-triggered) frame rate and will adjust packet size accordingly,
whereas Format 7 lets you set a packet size and it will adjust frame
rate accordingly. Again, this is without knowing what camera the
customer is using or what the camera file tells the driver to do when
the FrameRate attribute is set or changed. With that information we
could probably give a more specific explanation.
The frame rate camera attribute allows you to tweak the actual frame rate for a given video mode. So if you select 640 x 480 @ 30 fps, then the frame rate attribute will allow you change the specify a lower frame rate (1-30 fps). Note that in most cases, the camera will still use the same ROI and packet size. The only differences is when the camera will actually transmit the packet. This is helpful for free-running applications. This is not very useful for triggered applications.
