â03-04-2005 11:02 PM
â09-22-2006 12:25 PM
Hi mag93,
I'm not quite sure if I understand your question.
If you are using National Instrument FireWire driver, the driver wont find the port, until you'll have a camera conected to the port. If something is wrong with the cables, the driver could not detect the port. If you are using a laptop, and the firewire port has only 4 pins, then the camera is not getting any power from the laptop, so ti wont find the port, because the camera is not turn on.
Does this answer you question?
Tania Lozoya
â10-08-2006 06:59 AM
