‎11-26-2005 05:10 PM
‎11-26-2005 10:39 PM
Can you give some details about the cameras (like Manufac.)?
logic
‎11-27-2005
08:27 PM
- last edited on
‎04-18-2024
08:35 AM
by
Content Cleaner
https://www.ni.com/en-us/shop/category/machine-vision.html
https://www.ni.com/en-us/support/model.pcie-8255.html
‎11-28-2005 03:04 AM
Thanks for your contributions - I had looked at the LIGHTWISE sometime ago - I liked the specification especially the variable resolution.
The project requires inspection of 25mm Diameter tubing in real time as it is manufactured (line speed 0.5 meters per second).
Two cameras probably required - 1st camera backlit in order to measure the tubing outer contours. 2nd Camera front lit to do some blob analysis.
I suspect I will also need to do some Fourier analysis with camera 1.
