Machine Vision
FLIR Camera AOI setting in LabVIEW code.
BFS-U3-32S4M
On using the above USB3 camera, we were unable to change the Area of Interest below 900 pixel in labview. However, it was possible in NI MAX.
In a LabVIEW code - we got the attribute out of range error for the same.
Request for a solution for this.
(3,247 Views)
What values you tried to give for camera in code and MAX?
-Try running the Camera Validator and see which attribute is out of range.
-Get Camera Validator from C:\Program Files (x86)\National Instruments\NI-IMAQdx\Utility
-Generated report you can find in C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Compatibility Reports
uday
(3,221 Views)
Accepted by BodkinArrow
HI, Enabled acquisition frame rate in NI Max and ran the code. There was no error of limiting Area of Interest. Thanks.
(3,124 Views)
