Machine Vision
Vision Processing taking longer in .exe than in development
I am writing an application that uses some VIs from the Vision Development Module. I process thousands of frames in sequence and have been looking at the timing for the processing. I've found that, on average, it takes about 10ms per frame when I am in development and running my code from within LabVIEW. However, when I run my application as an exe, it takes an average of 25ms.
Has anyone seen this sort of behavior with the Vision Development? I would have expected to see shorter processing times in the exe since there would likely be less overhead and I'm not quite sure what I can do to troubleshoot it.
Eric
(2,670 Views)
-Is your development and exe running on same machine or different?
-Is there any difference in OS? Specifications of both systems if development and target machine are different?
-What algorithms your application consist of?
-Try with sample code and check with development and exe and see if they are having similar time variations.
-without code it will be difficult to guess, post code if possible.
uday
(2,629 Views)
