Machine Vision
取消
顯示結果
搜尋替代
您的意思是:
Ethernet switch and GigE camera
Using a CVS 1458 module, which includes 2 GigE ports, is it acceptable to connect 4 camera heads, either using one switch grouping all 4 and only one GigE port, or 2 switches grouping 2 cameras each and therefore using both GigE port (which sounds to be the best solution)? I want to use a resolution of 2048x1088 at 50fps. It is said that it is ok in the product description, but not specified anywhere else in the manual or specs.
Many thanks for your help.
0 積分
1 條訊息(共 15 條)
6,406 檢視
I got a bit confused what exactly your problem is is your problem calling two camera simultaneously ?
0 積分
2 條訊息(共 15 條)
6,374 檢視
Yes, the problem is to find out if it is acceptable/possible to have 2 cameras connected to one GigE port using a switch. I want "continuous" image recording from both of them.
0 積分
3 條訊息(共 15 條)
6,373 檢視
what is speed of imaging you intend to use this method for four camera
0 積分
4 條訊息(共 15 條)
6,372 檢視
I want to use a Basler ace with resolution of 2048x1088 and 50 fps frame rate (hope that answers your question). Not sure how to calculate, does that mean my required bandwidth would be 2048x1088=2.2MP at 50fps=110 MB/s?
I read that GigE allows about 100 to 125 MB/s in practice, therefore is it possible to connect both cameras through a switch to this GigE port on the CVS?
Thank you
0 積分
5 條訊息(共 15 條)
6,370 檢視
Look into this KB and related links: Does NI-IMAQdx Support Multiple Cameras on a GigE Switch? http://digital.ni.com/public.nsf/allkb/EC76AC9B636C6B63862575480003BBFF
uday
6 條訊息(共 15 條)
6,367 檢視
That is of great help, thank you. So that means the bandwidth will be shared by those two cameras, therefore it is not possible to have 50 fps for both cameras with this resolution, based on my understanding. It would be possible to have for instance 20-25fps, or lower resolution.
0 積分
7 條訊息(共 15 條)
6,361 檢視
check this link it could be helpful to know what you have to do
https://www.ptgrey.com/tan/10351
8 條訊息(共 15 條)
6,360 檢視
Great, I will read this in details. This device might also be more appropriate to what I need.
0 積分
10 條訊息(共 15 條)
6,357 檢視
