Hi Pavel,
When you have adjusted your settings for the camera and you acquire the image, you should have no problem displaying the results. If you are in Labview, the image should be acquired into a buffer of appropriate size. It is possible that I am misunderstanding, but the Labview buffer should be sized to the amount of pixels incoming.
A basic example of how to acquire an image can be found at:
..\Program Files\National Instruments\LabVIEW\examples\IMAQ\IMAQ High Level.llb\HL Grab.vi
If you are trying to resize an image you have already acquired, I would use the IMAQ extract VI, found on the functions palette at:
NI Measurements > Vision > Vision Utilities > Image Manipulation > IMAQ Extract
Hope this helps,
Robert
