Machine Vision
Can i use C Code at Compact Vision or Compact Rio?
hi,
i have a very important question!!
can i use the C code that the Vision Assistant generates, in the compact vision system, even in DLL form??? if yes, how can i download it to the compact vison?
can i use C code at the compact rio?
greets,
gerald
(4,306 Views)
Hi Gerald,
may be the following link could answer your question:
http://zone.ni.com/devzone/conceptd.nsf/webmain/4480b944338f965686256ded007a19cb
Steffen
(4,295 Views)
Hi!
Is it possible to download a template "pic.jpg" to the Compact Vision? As you know its possible to use color detection with a template in the NI Vision Builder AI or NI Vision Assistant....
greets gerald
(4,248 Views)
You could upload files to the CVS via ftp. Use your web browser for example and use "ftp://IP-ADRRESS" as URL. After that you can see partition C:\ of your target.
(4,238 Views)
ok its working... i can see the folders: ni-rt, TEMP
and files: hdmon.bin, nireg.dat, ni-rt.ini, persist.pal, ph_exec.exe
where can i save my picture for image processing? and whats the path to it?
bye
(4,225 Views)
Save your image where you want to save it. But make sure you use the right path in LabVIEW to open your image. I.e. "ftp://IP-ADRRESS" means "C:\" in your development enviroment. "ftp://IP-ADRRESS/custom folder" is "C:\custom folder".
(4,219 Views)
