 RichF
			RichF
			01-26-2010 03:32 PM
I currently am configuring a CVS-1456 for standalone use. Consequently, the video port is required to provide feedback to the operator.
I am using a Basler 70fps camera and I have it configured for format 7 128 x 100 to locate a moving target.
I have 2 states in the state diagram, one for trigger and determining the target type (single frame) and the second to locate the target precisely (Video >30fps).
If I am online with VBAI, the inspection states execute and display. If I am running standalone, the CVS video only displays the first state. The second executes but does not display.
I have displayed 30fps and above in the past with no trouble. Is there some setting I have to adjust?
Sincerely,
Rich
01-27-2010 03:41 PM
Hey Rich,
When you said that you have displayed 30fps and above in the past with no trouble. Were you using an executable or VBAI? Have you tried to use a slower fps in executable?
01-27-2010 04:20 PM
To be specific, in VBAI i can configure any framerate and there is no problem. The problem is with the executable.
In the executable, slower FPS does work but I have displayed nearly 60fps in the past on the VGA monitor.
Any ideas?
Rich
 Brad
			Brad
			01-27-2010 04:36 PM
