‎01-23-2006 09:23 AM
‎01-24-2006
09:43 AM
- last edited on
‎04-15-2025
08:36 AM
by
Content Cleaner
Hi Manu -
Unfortunately, NI doesn't provide any custom toolkits or functions for calculating 3D object contours that I know of. An application like this would probably require a stereoscopic acquisition and some image processing functions to detect edges and contours. If you do not already have a copy of the Vision Development Module, I recommend that you give it a look when researching this application.
Hopefully some of our forum gurus can help you further from their own experience with this type of application!
‎02-07-2006 08:57 AM
Hello David,
Thanks. In fact, I am working with Vision Development Module. And I would like to have one example of some thing similar, so that I can get some direction.
Thanks.
Manu
‎02-08-2006
01:55 PM
- last edited on
‎04-15-2025
08:36 AM
by
Content Cleaner
Hi Manu -
I was unable to find any examples of stereoscopic image acquisition or 3-D contouring on our website. However, you can find examples of how to use the NI Vision functions using NI Example Finder:
You might also consider employing the help of one of our NI Alliance members. The NI Alliance is a list of engineering contractors that develop advanced applications (like this one) using NI hardware and software.
‎02-16-2006 03:40 AM
‎02-21-2006 02:48 PM
‎02-21-2006 07:56 PM
Hello Oliver,
Thanks for your reply. The shape of the dome is very much similar to top quarter protion of the sphere (but its not a perfect sphere). And I need to measure these uncertainities of the spherical form during the dynamic forming process i.e. the spherical shape is formed from the flat sheet. The true measurement of the spherical form is important to study the behaviour of forming process. And I also don't have the flexibility of rotating the part. So in my view, the second option suggested by you "KLT point tracker " may work. I need to measure the highest point (height) and the curvature of the form. Then I will apply some mathematical equations to perform further analysis.
I had read about this random pattern generation on test part and then tracking them with two cameras, as they move during forming process in the z-direction. But I have no clue about this KLT point tracker algorithm. Any direction, whether it is a library function or something I have to code myself. Like where I should start and how!!
I would really appriciate your help in this regard and again thanks a lot for your reply.
Manu
‎02-23-2006 02:22 AM
