Machine Vision
Color Pattern Matching - Ignore Black and White options
I am using .net libraries in Vision Development Module to implement color pattern matching for my product and I encounter the following problem.
Since the product has an irregular shape, I create a template of product image with a background in black color (RGB: 255,255,255) and learn with the learn option "CWIMAQIgnoreBlackAndWhiteOptions.cwimaqIgnoreBlack". However, no match was found while matching with the photos of the realistic product. I even try on "Ignore White" option with a template of white color in background and "Ignore black and white" option, but nothing help.
If I modify the photo so that it's all black in color except the product (with irregular shape), then I got 998 in score while matching with the template that I created. I even tried these steps using Vision Assistant 8.0 and it returns the same result.
I wonder whether I misunderstand the defintion of CWIMAQIgnoreBlackAndWhiteOptions or I do not use it properly.
Any help is appreciated.
Best Regards,
Joanne
(3,042 Views)
Hi Joanne,
I posted a reply to your question at the link below. let's continue with that thread.
http://forums.ni.com/ni/board/message?board.id=232&message.id=2970
S. Arves S.
(3,034 Views)
