Machine Vision
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
-1074397163 error code from IMAQ init
I get this error when trying to init the camera in LabView 2010.  Reference name matches the setting found in Meas & Autom. explorer.  I can grab images there and manipulate the camera w/o problems.
After reading the various threads during my searches... the solutions offered did not fix this problem.  (multiple LV RTE's & name mis-match).  Tried LV 2010 & 8.5 with same results and I verified this with MAX closed as IIRC having it open will also create a similar problem.
Suggestions?
edit:  probably not going to help knowing this but the camera is an ATV  Stingray F504C
Messaggio 1 di 2
3.431Visualizzazioni
boy I really hate it when this happens... got it...  IMAQ init.vi generates the error, IMAQdx Open Camera.vi does not...  no problem now grabbing images.
I am good to go...
Messaggio 2 di 2
3.428Visualizzazioni
