MATRIXx
User defined SuperBlock
is it possible to define a SuperBlock in Systembuild? I want to create a SuperBlock for example with one input (that can not be deleted) and with a special graphical icon.
Thanks for helping me,
Jewgenij
(10,292 Views)
Hello Jewgenij,
I am not sure which version of MATRIXx you are using, but the SystemBuild help for MATRIXx 8 has a Creating a SuperBlock help topic in Chapter 2.
Hope this helps,
Angela M
(10,291 Views)
Hello Angela,
the Problem I have is not to create a SuperBlock with an input.
I want to define a new block template named like JewgenijBlock 🙂 . This new defined JewgenijBlock should be a normal SuperBlock which can contain other blocks and should have an input.
Then again this JewgenijBlock should have another icon, for example a circle.
The user of MATRIXx have then only to drag this JewgenijBlock from the library in his model to use it.
I hope you understand my problem now.
(10,288 Views)
