Lookout
unable to locate dll error [nidscmem.dll]
I downloaded the LK 5.0 demonstration version in my computer and I get the following error.
(Lookout.exe - Unable to locate dll
The dll nidscmem.dll could not be found in the specified path)
and then it lists the paths where it looked for it.
I then performed a search on all the drives in my computer and was not able to find this dll either. Why is this not being installed in my computer. Please help.
(3,612 Views)
Are you trying to install Lookout in the 😧 drive ?
If you try to install it in the C: drive do you get the same message ?
Andre
(3,612 Views)
I was trying to install Lookout in the D drive. I tried this several times and no luck. I then deleted all the registry entries related to Logos and Lookout. Then I installed Lookout once more but this time on the C drive and this worked. I didn't want to install it on the D drive anymore just in case it didn't work again. It was a lot of work deleting registry entries.
Anyhow, Do you suspect installation to the D drive generates an error like this? I don't need Lookout on the D drive but I am just curious.
(3,612 Views)
nidscmem.dll is in the logos download from the NI site
(3,612 Views)
