Lookout
pot object remote connection side effect
Hi folks,
I've found a little side effect in the remote connection of a pot object and its input limits. Sometimes it happens that the value input in the pot object is not written. See the attached project.
Mario Fanelli
(5,635 Views)
It looks like a side effect of the design. The data change event is generated only when the value is changed.
Ryan Shi
(5,626 Views)
Hi Ryan, Excuse me if I don't reply to your post quickly. What kind of side efffect of the design are you thinking about? Thanks
(5,615 Views)
I mean the design of lookout, not your process. As you said, the point is whether to generate the event when a same value is input.
Ryan Shi
(5,611 Views)
Hi Ryan,
Yes, I think so. The way to solve this effect is to input a wrong value inside the limits of the pot object an after input the correct value. This allow to generate the write event needed for changing the value at the limits of the pot.
Have a nice day
Mario Fanelli
(5,604 Views)
