Lookout
finding RTU address in Zetron Controllers
I am working with lookout 5.1 that is communicating with a Zetron RTU 1716 and 1700 controller. How do I find the addresses in lookout. I know the address in the Zetrons (dip switches) but how do I know I have the correct ones in lookout?
(5,834 Views)
What driver are you using to poll the device?
If the Zetron has Modbus capabilities then use the Modbus driver.
You can then set the address there.  You can also select serial coms or ethernet or Modbus Plus.
(5,811 Views)
I found my answer working with Zetron. Thanks for your time.
(5,808 Views)
