Lookout
embed variable in strings
Is there a way to embed variable data in a text string?  For example, "Water Level is 10.4 ft. "  where 10.4 is value of variable named Water_Level.
Chris
(5,921 Views)
An & is used to combine text and object and data member (if not implicit) in an expression.  Using your example, you would use a text expression with the following in the yellow field:
 “Water Level is “&ObjectName.DataMember &” ft.”
If you wanted to always display one decimal use the text function:
“Water Level is “&text(ObjectName.DataMember,”0.0”) &” ft.”
Hope this helps.
(5,919 Views)
