Lookout
Reading data from excel sheet in csv format using Datatable.
Hello everybody,
I have an application in which i'am exporting data using Spread sheet and it is saving in excel comma separated variable format.
I want to show that data on control panel using data table, but it cannot import data from excel in csv format
so i want to know that,  can we export data  in excel format bypassing csv format.
or is there any option to read data from excel csv format.
mantosh
(4,918 Views)
Hi Mantosh,
DataTable imports only from XLS files. The data you have appears to be a comma-separated, i.e., CSV data. Though Excel can open CSV files, it's not an XLS file -- until you save it as such.
So, the first option is to save the CSV data as an XLS file. If this cannot be done manually by a user, an Excel/VBA macro may be written to do this.
If the above isn't feasible, you have two options as I see it:
1. Read the CSV data as Text data. You will have to use DataSocket for this (search the forums). But it won't be pretty-looking: you'll see the data as you would in a Notepad.
2. Use the MS Office's SpreadSheet ActiveX control. this can display CSV data in an Excel format, using the CSVURL property. I just tested this and it works:
Hope this gives you some ideas.
-Khalid
Message Edited by Khalid on 05-03-2006 01:28 PM
(4,913 Views)
