Lookout
Programmatically save Ring control's value and label
Hi
I am adding Value and label in ring control by program. But when I close my application and start again at that time I lose that value and label. Is there anyway I can save dynamically also
(3,074 Views)
What object are you using for this? And what version of Lookout?
Khalid
(3,074 Views)
Hi Khalid
I didn't get your question about object. Actually I am using InsertListItem function to insert value in ring control and label. Regarding version I am using labwindow 6. I Hope this is what you are asking. If there is otherway to add value and label then please let me know
(3,074 Views)
Aha! So you're using LabWindows and not Lookout. This particular section of the Discussion forum is for Lookout -- NI's HMI / SCADA and Industrial Automation Software. (Hence my question about Object, which Lookout uses.)
You may want to post your query again in the right section:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=3&RHIDETAG=TRUE&UCATEGORY_0=_318&UCATEGORY_S=0
Khalid
(3,074 Views)
