Lookout
PLAYWAVE
How can I make a playwave file loop in Lookout 4.5.1 (build 19) until acknowledged. I am running Win XP Pro with Media Player 10 set to repeat any audio file selected but it does not repeat when in Lookout.
Thank you
(3,832 Views)
Do you use the ActiveX control?
In the property page, "play count" is the number of times it will repeat. I'm afraid you can't set it to repeat forever.
Ryan Shi
(3,826 Views)
Thank you for your solution, it solved my problem.
(3,786 Views)
