Lookout
Need Help for Getting 50 pin IDC ribbon cable
NI Community, I need one help on the Hardware Side.
I need an IDC 50 pin ribbon cable. I am looking for it from past 3-4 days but not able to find the proper one. I checked the official vendors of NI Product, and I got one on Digikey 154041-12 NI | Test and Measurement | DigiKey but the lead time is 8 weeks, and I don't have this much time. I got one from local vendor https://www.sunrom.com/p/50-way-frc-flat-ribbon-cable-per-foot but I don't know whether it will work or not?
Can anyone help me in getting the NI IDC 50 pin Ribbon Cable.
(3,115 Views)
Is it just a regular 50-pin to 50-pin IDC ribbon cable? which hardware breakout are you using?
Santhosh
Soliton Technologies
(3,089 Views)
Yes, As already mentioned, I am using NI SbRIO 9627 and I am looking for 50 Pin IDC Ribbon Cable with two female end connectors. I am also adding the screenshot of the cable it is mentioned in 6th.
(3,077 Views)
Need to access other DIO pins from SbRIO 2mm IDC Breakout - NI Community Please check this out I have mentioned it properly.
(3,004 Views)
There are a lot of options, a selection is for instance here: https://nl.mouser.com/c/wire-cable/cable-assemblies/ribbon-cables-idc-cables/?connector%20end%20a%20...
Rolf Kalbermatter  My Blog
(2,748 Views)
