Lookout
Multi window instances, DSC LabVIEW application
Hi
How can I develop a DSC LabVIEW application featuring multi window instances controlled by button (s) press on main (default) front view window?
In fact I have a large number of wireless sensors to be analyzed.
BR,
Nasq
(6,603 Views)
Create multiple labview VI. Use button to switch between VI. LabVIEW is able to programmtically open or close a VI, open or close a VI's panel.
For detailed information, please post this question on LabVIEW forum.
Ryan Shi
(6,589 Views)
You can also use the Tab control.
Ryan Shi
(6,588 Views)
Hi Ryan!
Thanks for reply. Creating multiple VIs is not a bad design option at all. However I fear it could compromise speed of an application which is also running active communication with database sources and a great number of sensors.
Let me try it. But thanks for suggestion.
BR
Nasq
(6,575 Views)
