Lookout
Modbus Communications address offset
Is there an option available in the Modicon Object to enable an address shift during communication with Modicon Devices.  When communicating with a Modicon Quantum PLC 400010 will return the value from the device in reg 400010 but when communication with a Modicon M340, Premium and others 400010 will return the value in 400009.
(12,880 Views)
We don't have such an option to shift the address.
The register address starts from 400001. What if you read address 400001 from Lookout?
Ryan Shi
(12,872 Views)
400001 will return 400000.  Some Modbus devices are 0 based (Quantum) and others are 1 based (Premium, M340).  We can change the alias address to reflect the offset but I was looking for something simple.
(12,867 Views)
I am having the exact same issue, upgrading about 30 PLCs from TSX Compact to Modicon M340. Now every address I reference in every PLC I upgrade is going to be offset by one from the address I need? There has to be some solution somewhere.
(11,994 Views)
Nothing a little data member export and import cant fix...
On the standard Koyo (automationdirect) PLCs we have to convert from Octal to decimal, then add 1.
For example:
PLC: V1200
Decimal: 640
MODBUS: 40641
Forshock - Consult.Develop.Solve.
(11,962 Views)
Finally found a solution deep in the M340 documentation. There are two system words, %SW139 and %SW141, that when put into the Data Editor and given a value allow the coil and register offset to be changed.
(11,945 Views)
Just found this forum recently.
Upgrading from TSX Compact to M340. The code in the TSX uses memory bit %M to send data to SCADA. The existing SCADA uses 40000x addressing, somehow there is a correlation between %M and 40000x which I don't understand. I've replicated the %M address into the new M340 and used the existing addressing in the CitectSCADA, however does not work. There seem to be offset can figure out, even tried to offset by 1 in the PLC.
1. Do you just enter %SW139 and %SW141 in the data editor only or need to add it in the logic?
2. Do you know if there is a direct correlation between %M and modbus 40000x addressing? Does %M1 = 400001, or can %M1 = 401013.1 so on?
Need help I am totally lost and stuck on this problem.
(2,289 Views)
