Lookout
Making a phone call from Lookout?
How can I dial out from Lookout via modem to
play prerecorded .wav�s until another party
disconnects / or a timeout occurs?
In other words I need to have a voice
messaging to report alarm conditions.
This would be a nice alternative to paging.
Sergei
(4,233 Views)
Lookout is known to work with third-party telphone alarm systems like Win911
and ScadaAlarm. Please check the following links for more info':
http://www.specterinstruments.com
http://www.fluidsolutions.com/O/scadalarm1.html
toma.inc@usa.net wrote:
How can I dial out from Lookout via modem to play prerecorded .wav�s until
another party disconnects / or a timeout occurs?
In other words I need to have a voice messaging to report alarm conditions.
Sergei
(4,232 Views)
OK, but that's not quite what I'm looking for.
It's a bit frustrating that Lookout can't simply
dial out via com port.
Sergei
> Hi,
> Regards,
> Sergei
(4,232 Views)
Sergei, if your Lookout PC is connected to local plc, then you could:
1. connect a phone in parallel with line going to modem used to page
2. use PLC output to activate relay that took this phone off hook
3. set alarm to play wave file thru pc speaker near phone
Whatever alarm condition causes page could be used to start this
sequence.
good luck
Robert Phillips
City of Wichita Falls, Tx
Sorry if double post since I'm a little confused if it post or not 😞
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,234 Views)
You may use U.C.ME-OPC software products from Control-See Software Solutions. See - www.controlsee.com .
It can generate phone calls and play a pre recorded voice messages. You may also dial in and perform several actions such as: Query tg value, change tag value and more.
U.C.ME-OPC uses OPC or DDE to connect to OPC servers, DDE servers or any SCADA/HMI software that supports OPC or DDE.
It may send alarms via: SMS, Phone/Voice, Email, Fax, WAP and more. It may also work as Windows service. A fully functional evaluation version may be downloaded at www.controlsee.com.
Michael
(3,942 Views)
