Lookout
Lookout crashes when i 'Edit Data Member Configuration'
SLC-500 Driver, Ethernet, SLC5/05 - only this one out of ten - im thinking something is corrupted.  Any way to fix it?  Or am i gona spend hours changing all the dependancies to a new driver?
(5,997 Views)
There is probably something wrong in this object datamembers. Try to open the .lks file to recompile it and edit it. If it doesn't crashes, the problem is in the process file(.l4p). But if not, the source file(.lks) has the problem. If you are familiar with the lookout source file, open is by text editor and try to find it out, or post it here.
Ryan Shi
(5,986 Views)
