Lookout
Lookout Warning - logged data out of time sequence
 what mean a warning :You have logged data out of time sequence. Repeated instances of logging "backwards" in time can result in overly large database files, and even data corruption.
When we use Lookout 6.1 and the Logger object to write data to citadel DB.
Pavel Rucka.
(6,490 Views)
For example, last time you logged value 10 at 10:00:00, then now you log a new value at 9:58:00, you will get the warning.
If the time datamember of Logger is not set, it will use the system time when it logs. The warning will happen when your system time is set back.
This is just a warning. The data will still be logged.
Ryan Shi
(6,476 Views)
Dear Ryan,
 thank you for the response. It's good information for me, If data will still be logged.
Pavel.
Message Edited by PavelRucka on 03-06-2008 01:39 AM
(6,473 Views)
