Lookout
Lookout 6.2 Hypertrend Panel Reports
I'm having issues getting reports with full panel graphics that contain hypertrends to properly update the trends prior to the report generationThe computer doing the reports does not actually have a monitor connected to itI'm using it as a developer machine and I remote control to do the developingThe behavior is the same however, even with a local monitor hooked up.
Issue is that the actual screen redraw seems necessary to make the panel ready for report generationThat is, if a screen saver is on, or a different panel is over the panel in the report, the report graphic will not have updated Hypertrend traces in the panel graphic of the report.
Anyone have a workaround to fool lookout into thinking the panel is active prior to generating the reportI've tried "popping" or activating the panel many seconds prior to the panel generation, but it does not seem to help.
Strangely, one of the 19 Hypertrends on the panel is always up-to-date, and the other 18 are only up to the point of the previous report.
Cheers,
Ed
Message Edited by erblock on 04-29-2009 10:32 PM
Message 1 of 1
(5,922 Views)
