Lookout
Lk 6.2 Crashes when you "Save All" in edit mode
From Lk 6.2 bugs post.  Thought this needs it's own thread.
I've had lots of crashes after "Save All" menu command while in edit mode.  Recently, the crashes were all after draging display objects to panels and/or copying objects between panels.  It is very repeatable.  Exiting edit mode prior to saves prevents crashes.
Ryan, can you confirm this and put on your fix list?
Ed
Message Edited by erblock on 04-29-2009 10:53 PM
(5,920 Views)
Ed,
I tried to drag some displays and save all, but could not reproduce the crash.
Have you tried to create a new process or load different process to repeat the crash? Maybe the crash is related to certain kind of process, or related to a certain object?
If possible, could you upload your process to the ftp site? The crash is more critical which should not happen in any situation.
Ryan Shi
(5,905 Views)
