Lookout
How to print a programatic range of alarms?
I am programatically printing the alarms from the last 24 hrs to a journal file and then querrying that file with SQL.  Problem is that my test can run for up to 72 hours and can end at any time any day of the week.  In the print setup, if I pick this week and the test ended at 6AM Monday, it would only return the last 6 hours of data.  Same problem ensues with month or year selections, albeit less freqently.  The ideal choice is to use the range parameters but I can not find a way to access those programatically.  Does anyone know of a way I can programatically set the range to print or any other way to do the same?  Thanks.
(5,831 Views)
I see that you can manually set the range and print the alarms. But I can't find a way to programatically set the range.
One way is to print today's alarm everyday.
Ryan Shi
(5,822 Views)
