Lookout
FP Error: Undefined Command
The error dialog box displays the following message for one of the FP-1001 units: "FP Error: Undefined Command". I have tried searching for this in support and discussion forums to no avail. I have tried a reset on that unit through FieldPoint Explorer and still the error. Any direction would be great.
(3,665 Views)
Tim,
That is a pretty general error that usually indicates that you may have sent an illegal command to the FieldPoint unit. So the best thing to do is track down where the error is occurring, i.e. what command are you sending when this error occurs. So for instance in LabVIEW you can use “Highlight Execution” to trace the progress of you program and see exactly when the error happens. If you can track down where that error is occurring, and what command is being sent then it will be easier to track down the problem.
-GDE
(3,644 Views)
