Lookout
Error when compiling .lks file from version 4.0.1 on 6.7 error: Invalid object pathname
Lookout Process File Compiler Version 6.7 (build 49153)
Copyright National Instruments111 1992-2013 All rights reserved.
F:\Software\Software\Lookout 6.75 Server\Import\default.lks
F:\Software\Software\Lookout 6.75 Server\Import\default.lks(2327): error: Invalid object pathname: ..\Timers\Timer_10_Second
F:\Software\Software\Lookout 6.75 Server\Import\default.lks(2540): error: Invalid object pathname: ..\Timers\Timer_10_Second
F:\Software\Software\Lookout 6.75 Server\Import\default.lks(2924): error: Invalid object pathname: ..\Timers\Timer_10_Second
F:\Software\Software\Lookout 6.75 Server\Import\default.lks(3086): error: Invalid object pathname: ..\Timers\Timer_10_Second
F:\Software\Software\Lookout 6.75 Server\Import\default.lks(3944): error: Invalid object pathname: ..\Timers\Timer_10_Second
(4,253 Views)
Accepted by topic author |_ookout
Some of the Panel Objects are in the root folder, not a sub folder.  For the 5 line numbers listed change text from "now(..\Timers\Timers_10_Second);" to either "now(Timers\Timers_10_Seconds);" or "now(\Timers\Timers_10_Seconds);".  Then your source should compile in Lookout 6.7.
(4,234 Views)
