Lookout
Constant event log of SQL Login attempts
Hi, running Lookout 6.7.1 in Win 8.1 and MSSQL 2008 R2. Have noticed several MSSQL login attempts a minute in the Event Log. Windows Defender and Avira have not detected any unusual activity. Although there was a recent crash of Lookout due to a SQL related error, Lookout appears to operate normaly. Trend screens behave and display the historical data fine. The login attempts will stop as soon as I kill the 'citadel5.exe' service. Very concerned about this activity and would like to stop it. Any ideas? Would appreciate any input.
The two reccuring event logs:
Date  12/31/2014 1:58:48 PM
Log  SQL Server (Current - 12/31/2014 10:49:00 AM)
Source  Logon
Message
Login failed for user 'NT AUTHORITY\SYSTEM'. Reason: Failed to open the explicitly specified database. [CLIENT: 10.1.5.99]
Source  Logon
Message
Error: 18456, Severity: 14, State: 38.
Thank you.
Neil
(7,327 Views)
I think I have this solved.  I'm running and old LV 8.5.1 with DSC module. This same issue (login failed for user 'NT AUTHORITY\SYSTEM) has plagued me for years, and I have seen it on many different versions of Windows, including Windows Server 2008 R2. In my case it added a new entry to Windows Event log at a rate of once every 10 seconds.
I found a recent post on Stack Exchange, followed it exactly, and it worked.
Use the command: SQLCMD -S {computer name}\CITADEL and follow the instructions from there
(4,155 Views)
