Lookout
Color won't change when alarm goes away
First, thanks to all that chimed in on my question about the file path.  I just took what worked in my previous vi and cut and pasted, then changed the strings.  I still didn't see any difference in the structure, but obviously it was there.
I have an rms overall numeric display that I check to see if the value is over an alarm threshold.  If so, I change the color of the text from green to yellow.  I nested two case structures.  The first case structure checks for the first alarm point.  Inside that case structure, I check to see if the level is above a second higher alarm.  If so, I change the text to red.  I use the 'NumText.TextColor' property node to accomplish this.  Works fine!  However, once the levels decrease to below the alarm points,  my alarms are not reseting, even though inside my case structure, I have a 'NumText.TextColor' set to green if the level is below the lowest alarm point.  How do I reset this?  By the way, this is all inside a While Loop.  I'll attach the logic.
Thanks in advance
Message 1 of 1
(6,316 Views)
