Lookout
Can't log modbus serial comunication
I'm trying to communicate with a device through Modbus, but I only get Too Short Exception. Then I want to view the communication log to see if there is some useful information there. The problem is that I don´t have active the "Serial Ports" under Options in Lookout. Then I can´t configure Lookout to log the communication. I have no open processes, just Lookout 6.0.2 running nothing.
Is there another way to log the communication or am I doing something wrong?
Thanks.
(6,464 Views)
I guess you are using lookout runtime software. The "serial port" is disable in runtime.
You can add the following codes to lookout.ini in lookout folder.
[COM1]
LineType=0
ReceiveGap=20
AlarmPriority=1
DiagnosticFileEnable=1
DiagnosticFile=d:\log.txt
DiagnosticAllHex=1
DiagnosticTimeStamp=1
DiagnosticTimeStampDateFormat=73
If you use com2, just input [COM2]. The file path can be changed as you like.
Ryan Shi
(6,456 Views)
Please let me know the Modbus Communication codes for binary Modbus in NI Lookout
Thank you
(5,360 Views)
