Lookout
Ascii object
I've been trying to use the ascii object to make a dialup connection and send
a simple string to the device at the other end. The problem is the string
needs to finish with a carriage return.
Is it possible to send carriage return and line feed commands as part of
an Ascci frame?
Alex
(3,558 Views)
Hello Alex,
You can use \r with your string to send a carriage return. Similarly, \f
sends a formfeed and \n sends a newline. See online help under ASCII Object
for other control characters.
Khalid
send a simple string to the device at the other end. The problem is the string
an Ascci frame?
Alex
(3,558 Views)
