Lookout
Accessing data in Lookout from LabVIEW
Is it possible to read/write data in Lookout 4.01 by using LabVIEW 6i
and datasocket technology? How can it be done? If not, how can it
otherwise be done? (Do I have to use an OPC server or a TCP/IP object in
Lookout).
Thanks in advance,
Oeistein Gregersen
Miros A/S
(3,631 Views)
This is possible by enabling Lookout as an OPC Server (must be done during
install) and using the Datasocket functionality to generate an OPC client in
LabVIEW. There is a Knowledge Base entry, including a program, which should
help get you going.
http://digital.ni.com/public.nsf/websearch/ea15f53db6fecca5862567240064df09
Guy McDonnell
"Tord Øistein Gregersen" wrote in message
news:39C6097C.DCA7A90C@miros.no...
> Lookout).
> Thanks in advance,
> Oeistein Gregersen
> Miros A/S
(3,631 Views)
