‎01-14-2011 03:41 AM - edited ‎01-14-2011 03:42 AM
Hello NI,
using CVI help (2010) and browsing the Index, I have double-clicked on '64-bit integer support'. The page that shows up, however, is not really related to this topic, see the screenshot below.
‎01-17-2011 07:07 AM
Hi Wolfgang,
thanks for your post. I filed a documentation error report to our R&D department.
‎01-18-2011 01:27 AM
Hi Wolfgang,
we fixed the issue. SP1 help will contain a correct link.
Thanks again for the notification.
‎01-18-2011 01:55 AM
Nice to hear ![]()
‎01-18-2011 10:43 AM
Wolfgang,
Thanks for reporting this, as always.
To be clear, this was actually a rogue entry in the help index. Unfortunately, there is no actual topic that that entry should be linked to, so the "fix" is simply to remove that entry from the index.
If you're still looking for some additional information regarding 64-bit integers, let me know, and I can try to help you find it.
Luis
