LabWindows/CVI
wrong link in help file
Hello NI,
using CVI help (2010) and browsing the Index, I have double-clicked on '64-bit integer support'. The page that shows up, however, is not really related to this topic, see the screenshot below.
(3,928 Views)
Hi Wolfgang,
thanks for your post. I filed a documentation error report to our R&D department.
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,892 Views)
Accepted by Wolfgang
Hi Wolfgang,
we fixed the issue. SP1 help will contain a correct link.
Thanks again for the notification.
Andreas Stark
(3,875 Views)
Nice to hear Smiley Happy
(3,870 Views)
Wolfgang,
Thanks for reporting this, as always.
To be clear, this was actually a rogue entry in the help index. Unfortunately, there is no actual topic that that entry should be linked to, so the "fix" is simply to remove that entry from the index.
If you're still looking for some additional information regarding 64-bit integers, let me know, and I can try to help you find it.
Luis
(3,850 Views)
